  2. AI硬件
  3. 对 M5 MAX 跑本地大模型有点失望
对 M5 MAX 跑本地大模型有点失望
50 帖子 13 发布者 511 浏览
  • 5 566656661
    基本上我是把上下文拉爆(日間Coding需要), 然後concurrency單純調1, 並沒有特別針對hermes做什麼特別優化 (也許研究一下會更好, 不過得要有空)
    @tony-wang @rolex-lo
    趁現在午休的時候跑了一下llama benchy
    llama-benchy \
      --base-url "http://localhost:7380/v1" \
      --model "Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP" \
      --tokenizer "$HOME/vllm/models/sakamakismile/Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP" \
      --pp 2048 \
      --tg 480 \
      --depth 0 1000 5000 10000 20000 50000 100000 150000 200000 \    #(不同上下文長度)
      --latency-mode generation \
      --skip-coherence \
      --concurrency 1 \
    Context Ladder
    | model                                    |             test |               t/s |     peak t/s |         ttfr (ms) |      est_ppt (ms) |     e2e_ttft (ms) |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |           pp2048 | 7741.01 ± 1375.30 |              |    373.94 ± 54.49 |    274.26 ± 54.49 |    373.94 ± 54.49 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |            tg480 |      68.87 ± 6.65 | 81.33 ± 3.68 |                   |                   |                   |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |   pp2048 @ d1000 |   8136.73 ± 32.84 |              |     474.32 ± 1.44 |     374.64 ± 1.44 |     474.32 ± 1.44 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |    tg480 @ d1000 |      67.73 ± 5.06 | 88.00 ± 5.72 |                   |                   |                   |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |   pp2048 @ d5000 |   6615.23 ± 22.79 |              |    1165.21 ± 3.86 |    1065.53 ± 3.86 |    1165.21 ± 3.86 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |    tg480 @ d5000 |      72.92 ± 3.56 | 89.33 ± 3.77 |                   |                   |                   |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |  pp2048 @ d10000 |   6008.73 ± 10.16 |              |    2104.88 ± 3.47 |    2005.20 ± 3.47 |    2104.88 ± 3.47 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |   tg480 @ d10000 |      65.25 ± 2.21 | 82.00 ± 4.32 |                   |                   |                   |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |  pp2048 @ d20000 |    5152.21 ± 0.52 |              |    4379.13 ± 0.52 |    4279.45 ± 0.52 |    4380.19 ± 0.46 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |   tg480 @ d20000 |      70.45 ± 1.27 | 89.67 ± 0.47 |                   |                   |                   |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |  pp2048 @ d50000 |    3690.36 ± 5.88 |              |  14203.66 ± 22.59 |  14103.98 ± 22.59 |  14205.86 ± 22.80 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |   tg480 @ d50000 |      67.03 ± 1.67 | 84.67 ± 0.47 |                   |                   |                   |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP | pp2048 @ d100000 |    2528.58 ± 0.55 |              |   40457.51 ± 8.72 |   40357.83 ± 8.72 |   40461.50 ± 8.69 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |  tg480 @ d100000 |      60.96 ± 0.75 | 78.33 ± 3.68 |                   |                   |                   |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP | pp2048 @ d150000 |    1922.36 ± 0.98 |              |  79194.84 ± 39.68 |  79095.17 ± 39.68 |  79201.49 ± 39.50 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |  tg480 @ d150000 |      62.53 ± 3.29 | 76.33 ± 1.89 |                   |                   |                   |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP | pp2048 @ d200000 |    1556.00 ± 0.99 |              | 129951.65 ± 82.49 | 129851.97 ± 82.49 | 129959.72 ± 82.53 |
    | Huihui-Qwen3.6-27B-abliterated-NVFP4-MTP |  tg480 @ d200000 |      59.58 ± 1.31 | 69.67 ± 1.70 |                   |                   |                   |
    Token速度相當可用, 200K上下都能大約有60 tks
    A 在线
    A 在线
    @566656661 说:
    llama-benchy \
      --pp 2048 \
      --tg 480 \
      --skip-coherence \
      --concurrency 1 \
    Context Ladder
    看了都觉得爽, 可惜买不起
    Tony WangT 1 条回复 最后回复
      @566656661 说:
      llama-benchy \
        --pp 2048 \
        --tg 480 \
        --skip-coherence \
        --concurrency 1 \
      Context Ladder
      看了都觉得爽, 可惜买不起
      Tony WangT 在线
      Tony WangT 在线
      @applejuice
      他这张是 Pro 4500,比M5 max便宜很多,性价比很好,只是显存稍显紧张一点儿
      5 1 条回复 最后回复
        @applejuice
        5 在线
        5 在线
        技术大牛
        编写于 最后由 566656661 编辑
        #43
        @Tony-Wang
        因爲我不會在這臺小主機上面玩ComfyUI, 所以基本上基本上就是跑27b或者31b, 兩個NVFP4下模型大約20GB左右, 剩下的10GB基本上全部都是KV Cache. 沒有特別遇到什麽VRAM吃緊的問題的
        超長上下文 或者 3到4個 32K長度的并行Agent, 還蠻不錯的
        • 5 566656661
          @Tony-Wang
          Tony WangT 在线
          Tony WangT 在线
          @566656661
          嗯, 这个用途肯定是足够用了.
            @johnnybegood
            M5 Max 跑 Qwen 122b a10b Q4 的话, 如果内存够, 不大可能只有 20-25t/s.
            我的M5 pro 跑 Qwen 27b 稠密加上MTP之后, 还能跑到20以上, 64k上下文时候掉到 17多.
            按这个速度推理, M5 max 是我显存带宽的两倍, 它能到 40t/s 以上.
            122b A10b 肯定比27b 稠密要快, 应该能跑到 60t/s以上, 我估计.
            另外, 122A10 的智力应该不如 27b 稠密, 只是知识面更宽.
            Z 离线
            Z 离线
            zorg
            @Tony-Wang 说:
            @johnnybegood
            请教一下Tony的Qwen27B MTP用的哪个版本的模型?我下了oQ8-mtp,omlx经常退出,看日志好像是mtp的bug,求推荐稳定运行的模型版本,谢谢!
              我看介绍说 涡轮转速不可调, 是完全固定转速的意思? 还是说它自己智能调整, 不接受外部的转速调整?
              benton yiB 请勿打扰
              benton yiB 请勿打扰
              benton yi
              编写于 最后由 benton yi 编辑
              #46
              @Tony-Wang 涡轮卡的散热策略偏安静,max-q的出厂设置在300w功耗,温度干到90度的时候风扇也只吹到80%。都是可调整的,up说的不可调整估计是用官方的NVIDIA X Server Settings工具,温控功能确实是置灰的不能调。这个问题当时也是卡了我一下午,问了几个大模型,推荐了若干工具。最后试过一遍之后,LACT工具完美解决,拉一拉曲线都能整,小工具还支持多卡不同曲线。4090+max-q已测试通过非常好用,up也可以试试看
              5 1 条回复 最后回复
              • benton yiB benton yi
                5 在线
                5 在线
                技术大牛
                @benton-yi
                對, 就是指X Server Setting, LACT估計是用Rust或者C++去控制韌件, 有新卡或者升到新版本的Ubuntu就大機率需要更新+重裝
                • tomcatzhT 在线
                  tomcatzhT 在线
                  tomcatzh
                  楼主可以看看我的帖子
                  https://lcz.me/topic/546,不小心放到另一个区了
                    @kop-wang
                    期待分享, 我买的丽台的, 38999. 不过我要7月初才能回国装机.
                    张老师张 在线
                    张老师张 在线
                    张老师
                    @Tony-Wang 大佬,你躺着已经赚钱了,今天丽台的pro5000 48G 价格已经42299了
                    • Tony WangT 在线
                      Tony WangT 在线
                      看到了, 还好及时入手了一张. 🙂
